Grinding/Polishing in SprutCAM Robot
Free trial
Try a 30 day full feature free trial
Comprehensive library of robots and CNC machines
Save time with pre-configured equipment from the library
Knowledge base
Online courses, knowledge base and forum
How Grinding / Polishing works
Simulate and test your Grinding / Polishing operation on your PC. SprutCAM Robot has all that you need for it.
All the work is done in an interactive mode. The CAD/CAM system helps you to quickly create a grinding/polishing toolpath.
  1. Add a special operation – 5D Contouring
  2. Generate a toolpath
  3. Simulate and verify it
  4. Edit the toolpath interactively if necessary
  5. Start your robot with the G-code obtained
In SprutCAM Robot you can combine grinding / polishing with other operations. For example you can use grinding / polishing after a pick-and-place operation.
Use diverse equipment
The robot can hold a workpiece or a tool
Tool-to-part
Robot is holding the Grinding/Polishing tool. The workpiece is in a special holder, for example a vise.
Part-to-tool
Robot is holding the workpiece. The tool (for instance a polishing belt) does Grinding or Polishing.
Use various robots
SprutCAM Robot has a comprehensive library of 3D models and postprocessors for robots
Main features
for a productive workflow
Main features
Simulation in real time
In SprutCAM Robot you work with a 3D model of your robot cell. Because it’s convenient and visual.
Our library has more than 300 models of robots usable out of the box.
You can build your robot cell in our special app – MachineMaiker 2.0
Main features
Control additional axes
Besides the robot and CNC machine themselves, SprutCAM ensures control of an unlimited number of linear and rotary positioning axes.
Main features
Full Grinding / Polishing process control
Our Axis map tool helps to easily detect and bypass collisions:
  • Envelope limitations;
  • “Out of reach” cases;
  • Singularities;
  • Other collisions.
You can correct your toolpath automatically or do it manually selecting points on the curve.
Best working experience
You get all you need for effecient and сonvenient work 🚀 🚀 🚀
Use our library
A comprehensive library of CNC machines 3D models and postprocessors. Simply install SprutCAM and start using it.
Or create a new machine or machining cell
Use our special app MachineMaker 2.0.
Zero-code tool for building Robot cells. MachineMaker is included in the SprutCAM Robot installation package.
Robot model in MachineMaker 2.0Robot model in SprutCAM Robot
Examples
Our clients are already using Grinding/Polishing operations in their manufacturing workflow
Install SprutCAM X
Download trial version
Get SprutCAM X
Find a dealer
CNC machines and industrial robots programming solutions
Explore other CNC machines and industrial robots programming solutions provided by SprutCAM
