Meet SprutCAM X
SprutCAM X | SprutCAM X
  • Model tab is for 3D model design, import and transformation
  • Machining tab is for creation of technological sequence. 80% of job is done here
  • Simulation speaks for itself
SprutCAM X | SprutCAM XInspector is the place there all the technology parameters are defined: job zone, toolpath strategy, tolerance, interpolation, approach and retract, links, feeds and speeds, toolpath transformation etc
SprutCAM X | SprutCAM XMachining operations sequence
SprutCAM X | SprutCAM XUseful tools for everyday work: virtual machine pendant, tape measure, postprocessor, machining report, tool management, verify and compare tool, tool reach inspector, axes graph and 3d model transformation tools.
SprutCAM X | SprutCAM XSprutCAM X is machine aware CAD/CAM platform. This means that toolpath calculation is performed taking into an account machine kinematics and limitations. So machine digital twin is used for toolpath calculation and simulation after that
SprutCAM X | SprutCAM XPrecise and smooth simulation of workpiece evolution through the machining process. Either for machining or for additive processes
SprutCAM X | SprutCAM XThe main working area. Here are machine digital twin, part, workpiece, tools are shown. SprutCAM X Robot shows the interactive elements and simulation in this area
Machine-aware CAD/CAM platform
SprutCAM X introduced the Machine-Aware programming approach back in 2001, establishing it as the high-end foundation for a CAM software. This innovative approach involves considering machine limitations during the initial toolpath calculation, setting it apart from traditional CAM methods that operate in abstract space before converting to real machine code during simulation or postprocessing.
As machine kinematics become increasingly complex, the benefits of the Machine-Aware approach continue to grow. This advanced CAD/CAM software not only ensures appropriate safety for programming 5-axis and mill-turn machines but also provides a foundation for a transparent and intuitive user experience.
Your CNC Machine digital twin
The MachineMaker app allows you to generate a digital replica of your CNC machine in a matter of minutes. This digital twin is intended for use in programming the CNC machine within the CAD/CAM software SprutCAM X.
Furthermore, MachineMaker features an extensive library of readily available individual components, as well as complete pre-designed digital twins of CNC machines and postprocessors.
CNC machine digital twin
Product Highlights
A wide range of machining strategies from 2D to 5D
cnc programming software
nc code
G-code simulation and transformation to other CNC formats
cad/cam software
Interactivity
Machining result verification
cad/cam software
Parametric CAD
Stock-Aware Toolpath
cad/cam software
Collision-free rapid positioning between toolpath cutting cycles
3 axis cam
Crisp and clear interface with support of 4K display
cad/cam software interface
Multi-part projects supported
Snapshots
CAD/CAM software with AI assistant
AI Assistant
Applications
2.5x and 3x mill
Production of molds & dies and other parts on a 3-axis milling machine
3 axis cam software
Rotary
Production of screws, blades, gear wheels, balusters
4 axis cam, rotary machining
Lathe
Turning and boring, threading, trimming, drilling, reaming
cam for lathe machine
Mill-turn
Turning and milling in one setup
mill-turn machining
Multiaxis
Index (3+2) and simultaneous 5 axis milling. For turbine wheels, blades, ports
5 axis cam software
HSM and adaptive
High speed and adaptive toolpaths for quick material removal with extended tool life
high speed machining
Swiss and MTM
Swiss-type machines and MTM (multitasking machining) with synchronization
swiss type cam software
5-6D cutting
CNC programming of cutting, trimming, 6D knife cutting. Mill, laser, water, plasma, knife
knife cutting cam software
Additive and hybrid
Cladding, hybrid technology on 5-axis, mill-turn machines and robots
additive manufacturing
EDM
2 – 4 axis strategies for Wire EDM machining
wire edm programming
2D cutting
Programming of laser, waterjet, plasma, oxy-fuel cutting and knife cutting
2d cutting cnc programming
G-code based simulation
G-code verification in SprutCAM
cad/cam g-code simulation
Probing cycles
Probing cycles for Milling and Lathe Machines
probing and measuring cnc programming
Technology highlight:
Adaptive SC
This high-speed machining cycle is specifically designed for roughing to substantially decrease cycle times and extend tool life. Its technology automatically regulates chip loads and lateral cutting forces while maintaining the cutter engagement angle and machine axes acceleration within optimal ranges.
With Adaptive SC, the machine can make deeper cuts at higher feedrates, which are also automatically optimized throughout the toolpath for maximum efficiency. In comparison to traditional machining methods, Adaptive SC provides the following benefits:
70%
reduction in cycle time
500%
increase in tool life
Applications
Production of molds & dies and any other parts on a 3-axis milling machine
SprutCAM X | SprutCAM XProduction of screws, blades, gear wheels, balusters
SprutCAM X | SprutCAM XTurning and boring, threading, trimming, drilling, reaming
SprutCAM X | SprutCAM XTurning and milling combined in one setup
SprutCAM X | SprutCAM XIndex (3+2) and simultaneous 5 axis milling. For turbine wheels, blades, ports
SprutCAM X | SprutCAM XHigh speed and adaptive toolpaths for quick material removal with extended tool life
SprutCAM X | SprutCAM XSwiss-type machines and MTM (multi-channel machining) with synchronization
SprutCAM X | SprutCAM XCNC programming of cutting, trimming, 6D knife cutting. Mill, laser, water, plasma, knife
SprutCAM X | SprutCAM XCladding, hybrid technology on 5-axis, mill-turn machines and robots
SprutCAM X | SprutCAM X2 – 4 axis strategies for wire EDM machining
SprutCAM X | SprutCAM XProgramming of laser, waterjet, plasma, oxy-fuel cutting and knife cutting
SprutCAM X | SprutCAM XG-code verification in SprutCAM
SprutCAM X | SprutCAM XProbing cycles for Milling and Lathe Machines
Adaptive SC
70%
500%
Ready to embark on your SprutCAM X journey?
Select your preferred path
Get a trial version
Install a free 30-days trial version of SprutCAM X or SprutCAM X Robot. Take online courses and get a certificate.
Request a quote
Find a local SprutCAM X dealer and get a quote for a turnkey solution.
